Saltar al contenido principal
Maylong M-270 Motherboard Replacement
Qué necesitas
  1. Maylong M-270 Motherboard Replacement, Motherboard: paso 1, imagen 1 de 2 Maylong M-270 Motherboard Replacement, Motherboard: paso 1, imagen 2 de 2
    • Use the plastic opening tool to separate the back cover plate from the front.
    • Insert the plastic opening tool in between the back plate cover and the top cover, then slide along edges to pry open.
  2. Maylong M-270 Motherboard Replacement: paso 2, imagen 1 de 2 Maylong M-270 Motherboard Replacement: paso 2, imagen 2 de 2
    • Locate the two ribbons attached to the device's motherboard.
    • Flip the small black plastic catches down by using the small end of the spudger.
    • Remove the ribbons by gently pulling them away from the motherboard.
  3. Maylong M-270 Motherboard Replacement: paso 3, imagen 1 de 2 Maylong M-270 Motherboard Replacement: paso 3, imagen 2 de 2
    • Remove the two screws from the motherboard.
    • Remove the four screws and metal holds from the edge of the device.
  4. Maylong M-270 Motherboard Replacement: paso 4, imagen 1 de 1
    • Remove the motherboard by gently pulling it away from the bottom of the device.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 534
