Saltar al contenido principal
Mayflash Arcade Stick F300 USB Cable Replacement
Qué necesitas
  1. Mayflash Arcade Stick F300 USB Cable Replacement, Metal Backplate: paso 1, imagen 1 de 3 Mayflash Arcade Stick F300 USB Cable Replacement, Metal Backplate: paso 1, imagen 2 de 3 Mayflash Arcade Stick F300 USB Cable Replacement, Metal Backplate: paso 1, imagen 3 de 3
    • Flip the controller upside down so that the metal panel is facing you.
    • Remove the six 11 mm screws securing the metal panel using a Phillips #2 screwdriver.
    • Once all screws are removed, lift off the panel.
  2. Mayflash Arcade Stick F300 USB Cable Replacement, USB Cable: paso 2, imagen 1 de 2 Mayflash Arcade Stick F300 USB Cable Replacement, USB Cable: paso 2, imagen 2 de 2
    • Remove the four 10 mm truss head screws securing the PCB to the plastic outer casing using a Phillips #1 screwdriver.
  3. Mayflash Arcade Stick F300 USB Cable Replacement: paso 3, imagen 1 de 3 Mayflash Arcade Stick F300 USB Cable Replacement: paso 3, imagen 2 de 3 Mayflash Arcade Stick F300 USB Cable Replacement: paso 3, imagen 3 de 3
    • Use a hair dryer or heat gun to soften the glue holding the USB cable into the socket on the PCB.
    • It should take less than a minute for the glue to be soft enough to remove. Do not overheat the circuit board.
    • Use a metal spudger to gently remove the softened glue.
    • Remove the cable from the socket
  4. Mayflash Arcade Stick F300 USB Cable Replacement: paso 4, imagen 1 de 3 Mayflash Arcade Stick F300 USB Cable Replacement: paso 4, imagen 2 de 3 Mayflash Arcade Stick F300 USB Cable Replacement: paso 4, imagen 3 de 3
    • Slide the strain relief segment of the USB cable out of the plastic outer casing.
    • Remove the cable.
Conclusión
Jess Anderson
Miembro Desde 09/04/24
327 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 40
Todo El Tiempo: 103
