Saltar al contenido principal
Mayflash Arcade Stick F300 Joystick Replacement
Qué necesitas
  1. Mayflash Arcade Stick F300 Joystick Replacement, Metal Backplate: paso 1, imagen 1 de 3 Mayflash Arcade Stick F300 Joystick Replacement, Metal Backplate: paso 1, imagen 2 de 3 Mayflash Arcade Stick F300 Joystick Replacement, Metal Backplate: paso 1, imagen 3 de 3
    • Flip the controller upside down so that the metal panel is facing you.
    • Remove the six 11 mm screws securing the metal panel using a Phillips #2 screwdriver.
    • Once all screws are removed, lift off the panel.
  2. Mayflash Arcade Stick F300 Joystick Replacement, Joystick: paso 2, imagen 1 de 2 Mayflash Arcade Stick F300 Joystick Replacement, Joystick: paso 2, imagen 2 de 2
    • Detach the micro switch cables connected to the PCB (printed circuit board).
  3. Mayflash Arcade Stick F300 Joystick Replacement: paso 3, imagen 1 de 3 Mayflash Arcade Stick F300 Joystick Replacement: paso 3, imagen 2 de 3 Mayflash Arcade Stick F300 Joystick Replacement: paso 3, imagen 3 de 3
    • Use a flathead screwdriver to hold the bottom screw of the joystick lever in place.
    • Flip the device over.
    • Grab the ball top of the joystick and twist while the screwdriver prevents the screw from turning.
    • Once the ball top is removed, slide off the plastic tube and plate from the joystick.
  4. Mayflash Arcade Stick F300 Joystick Replacement: paso 4, imagen 1 de 3 Mayflash Arcade Stick F300 Joystick Replacement: paso 4, imagen 2 de 3 Mayflash Arcade Stick F300 Joystick Replacement: paso 4, imagen 3 de 3
    • Flip the device over again, exposing the inside.
    • Use a Phillips #1 screwdriver to remove the four screws holding down the joystick lever.
    • Slide the joystick out of the outer plastic casing.
Conclusión
Jess Anderson
Miembro Desde 09/04/24
327 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 60
Todo El Tiempo: 131
