Saltar al contenido principal
Matsunichi MarquisPad MP977 Front Facing Camera Replacement
Qué necesitas
  1. Matsunichi MarquisPad MP977 Front Facing Camera Replacement, Front Facing Camera: paso 1, imagen 1 de 1
    • Using the PH #00 Phillips head screwdriver, unscrew the two screws.
  2. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: paso 2, imagen 1 de 3 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: paso 2, imagen 2 de 3 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: paso 2, imagen 3 de 3
    • Place the device face down on a flat surface.
    • Insert the wide-tipped plastic opening tool into the top of the left speaker slot.
    • Be sure not to puncture the covering of the speaker.
    • Pry the back plate open and slide the tool in a clockwise direction, moving it along the opening between the device and the back plate until you reach the power button.
  3. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: paso 3, imagen 1 de 2 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: paso 3, imagen 2 de 2
    • Insert the opening tool into the slot located to the right of the speaker, at the top edge of the device.
    • Then, pry open the back plate of the device , and slide the tool counter clockwise along the device until you reach the charging port.
  4. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: paso 4, imagen 1 de 1
    • Remove the back plate and place it to the side of the device.
  5. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: paso 5, imagen 1 de 1
    • With the same screw driver, PH #00 Phillips head, remove the seven screws holding in the motherboard.
    • Place the screws somewhere safe where they wont fall.
  6. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: paso 6, imagen 1 de 2 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: paso 6, imagen 2 de 2
    • Gently pull the camera optic fiber out of it's slot to release the flap. This will allow the flap to open easily.
    • Be sure not to damage the camera port.
  7. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: paso 7, imagen 1 de 2 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: paso 7, imagen 2 de 2
    • Last, Insert the new camera into the pinhole camera slot.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 240
