Saltar al contenido principal
Matsunichi MarquisPad MP977 Battery Replacement
Qué necesitas
  1. Matsunichi MarquisPad MP977 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the two screws using a Phillips #00 screwdriver.
  2. Matsunichi MarquisPad MP977 Battery Replacement: paso 2, imagen 1 de 3 Matsunichi MarquisPad MP977 Battery Replacement: paso 2, imagen 2 de 3 Matsunichi MarquisPad MP977 Battery Replacement: paso 2, imagen 3 de 3
    • Place the device face down on a flat surface.
    • Insert one of the wide-tipped, plastic opening tools into the top of the left speaker slot.
    • Be sure to avoid puncturing the covering of the speaker.
    • Pry the back plate open and slide the tool in a clockwise direction, moving it along the opening between the device and its back plate until you reach the power button.
  3. Matsunichi MarquisPad MP977 Battery Replacement: paso 3, imagen 1 de 2 Matsunichi MarquisPad MP977 Battery Replacement: paso 3, imagen 2 de 2
    • Insert the opening tool into the right speaker slot.
    • Pry open the back plate, and slide the tool counterclockwise along the device until you reach the charging port.
  4. Matsunichi MarquisPad MP977 Battery Replacement: paso 4, imagen 1 de 1
    • Remove the back plate and place it to the side.
  5. Matsunichi MarquisPad MP977 Battery Replacement: paso 5, imagen 1 de 2 Matsunichi MarquisPad MP977 Battery Replacement: paso 5, imagen 2 de 2
    • Detach the battery from the motherboard.
Conclusión
3 personas más completaron esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 1,533
