Introducción
The Matsunichi M97 was a cheap alternative to the more common tablets. But it has its faults. Due to charging issues and/or functionality problems, the motherboard may need to be replaced. This guide will aid in diagnosing any problems with the device.
Qué necesitas
Remove the six 2mm screws that hold the motherboard onto the case using the Phillips #00 screwdriver.
Use the same screwdriver to remove the single 4mm screw.
Casi Terminas!
Conclusión
