Saltar al contenido principal
Matsunichi M97 9 inch Camera Replacement
Qué necesitas
  1. Matsunichi M97 9 inch Camera Replacement, Battery: paso 1, imagen 1 de 1
    • Open the micro SD cover located on the back of the device.
  2. Matsunichi M97 9 inch Camera Replacement: paso 2, imagen 1 de 1
    • Using the Phillips #00 screwdriver, remove the two 4mm screws next to the micro SD port.
  3. Matsunichi M97 9 inch Camera Replacement: paso 3, imagen 1 de 3 Matsunichi M97 9 inch Camera Replacement: paso 3, imagen 2 de 3 Matsunichi M97 9 inch Camera Replacement: paso 3, imagen 3 de 3
    • Use the iFixit opening tool to pry off the back cover of the device.
    • The volume buttons and the lock switch will come loose when the back comes off.
  4. Matsunichi M97 9 inch Camera Replacement: paso 4, imagen 1 de 2 Matsunichi M97 9 inch Camera Replacement: paso 4, imagen 2 de 2
    • Use a pair of tweezers to disconnect the battery from the motherboard.
  5. Matsunichi M97 9 inch Camera Replacement: paso 5, imagen 1 de 2 Matsunichi M97 9 inch Camera Replacement: paso 5, imagen 2 de 2
    • Carefully unstick the battery from the frame using the spudger.
    • Do not bend or puncture the battery during removal.
  6. Matsunichi M97 9 inch Camera Replacement, Motherboard: paso 6, imagen 1 de 2 Matsunichi M97 9 inch Camera Replacement, Motherboard: paso 6, imagen 2 de 2
    • Remove the six 2mm screws that hold the motherboard onto the case using the Phillips #00 screwdriver.
    • Use the same screwdriver to remove the single 4mm screw.
  7. Matsunichi M97 9 inch Camera Replacement: paso 7, imagen 1 de 2 Matsunichi M97 9 inch Camera Replacement: paso 7, imagen 2 de 2
    • Gently pull the display ribbon cable to unplug it from the motherboard.
  8. Matsunichi M97 9 inch Camera Replacement: paso 8, imagen 1 de 1
    • Use a spudger or an iFixit opening tool to lift the locking mechanism holding the camera ribbon cable.
  9. Matsunichi M97 9 inch Camera Replacement: paso 9, imagen 1 de 2 Matsunichi M97 9 inch Camera Replacement: paso 9, imagen 2 de 2
    • Lift up on the wifi antenna cable to unsnap it from the motherboard.
    • Then unhook the cable from the holding bracket.
  10. Matsunichi M97 9 inch Camera Replacement: paso 10, imagen 1 de 2 Matsunichi M97 9 inch Camera Replacement: paso 10, imagen 2 de 2
    • Use the spudger or iFixit opening tool to lift up on the locking mechanism for the digitizer ribbon cable.
    • Pull the cable from its connection.
  11. Matsunichi M97 9 inch Camera Replacement: paso 11, imagen 1 de 2 Matsunichi M97 9 inch Camera Replacement: paso 11, imagen 2 de 2
    • Use the Phillips #00 screwdriver to remove the four 4mm screws that hold the speakers in place.
  12. Matsunichi M97 9 inch Camera Replacement: paso 12, imagen 1 de 1
    • Pull the vibration motor out of its housing.
  13. Matsunichi M97 9 inch Camera Replacement: paso 13, imagen 1 de 2 Matsunichi M97 9 inch Camera Replacement: paso 13, imagen 2 de 2
    • Lift the motherboard off the frame.
  14. Matsunichi M97 9 inch Camera Replacement, Camera: paso 14, imagen 1 de 2 Matsunichi M97 9 inch Camera Replacement, Camera: paso 14, imagen 2 de 2
    • Remove the camera from the device.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 41
