Saltar al contenido principal
MasterCraft Eliminator Waterproof Spotlight Battery Replacement
Qué necesitas
  1. MasterCraft Eliminator Waterproof Spotlight Battery Replacement, Battery: paso 1, imagen 1 de 2 MasterCraft Eliminator Waterproof Spotlight Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Twist the front cover of the spotlight in a counter-clockwise rotation and remove it from the device.
  2. MasterCraft Eliminator Waterproof Spotlight Battery Replacement: paso 2, imagen 1 de 2 MasterCraft Eliminator Waterproof Spotlight Battery Replacement: paso 2, imagen 2 de 2
    • Remove the rear piece which is the protection cover for the charging port.
  3. MasterCraft Eliminator Waterproof Spotlight Battery Replacement: paso 3, imagen 1 de 2 MasterCraft Eliminator Waterproof Spotlight Battery Replacement: paso 3, imagen 2 de 2
    • Using the JIS #00 screwdriver, remove the two screws securing the motherboard to the device.
  4. MasterCraft Eliminator Waterproof Spotlight Battery Replacement: paso 4, imagen 1 de 3 MasterCraft Eliminator Waterproof Spotlight Battery Replacement: paso 4, imagen 2 de 3 MasterCraft Eliminator Waterproof Spotlight Battery Replacement: paso 4, imagen 3 de 3
    • Using the JIS #00 screwdriver, remove the single screw securing the charging port and remove the charging port from the device.
  5. MasterCraft Eliminator Waterproof Spotlight Battery Replacement: paso 5, imagen 1 de 3 MasterCraft Eliminator Waterproof Spotlight Battery Replacement: paso 5, imagen 2 de 3 MasterCraft Eliminator Waterproof Spotlight Battery Replacement: paso 5, imagen 3 de 3
    • Carefully disconnect the battery and remove it from the device.
Conclusión
Una persona más ha completado esta guía.
Un comentario
Can you get the 3wledbulb
olddoc55 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 50
Todo El Tiempo: 1,515
