Introducción
If your device is not connecting properly, it might be necessary to replace the Bluetooth wireless connector. This guide will show 7 steps for removing the wireless connector. Soldering is required for this replacement, If you don't know how to solder, click here for a great guide.
Qué necesitas
Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
Remove the 2mm screw holding the side cover plate in place with a JIS #00 screwdriver.
Move the side cover off to the side.
