Saltar al contenido principal
Master and Dynamic MW50 Right/Left Speaker Replacement
Qué necesitas
  1. Master and Dynamic MW50 Right/Left Speaker Replacement, Master and Dynamic MW50 Disassembly: paso 1, imagen 1 de 3 Master and Dynamic MW50 Right/Left Speaker Replacement, Master and Dynamic MW50 Disassembly: paso 1, imagen 2 de 3 Master and Dynamic MW50 Right/Left Speaker Replacement, Master and Dynamic MW50 Disassembly: paso 1, imagen 3 de 3
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Right/Left Speaker Replacement: paso 2, imagen 1 de 1
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Right/Left Speaker Replacement: paso 3, imagen 1 de 1
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Right/Left Speaker Replacement, Right/Left Speaker: paso 4, imagen 1 de 1
    • Desolder the two wires connected to the speaker.
  5. Master and Dynamic MW50 Right/Left Speaker Replacement: paso 5, imagen 1 de 1
    • Use a heating gun to remove the glue from the speaker.
    • Once the glue is removed, gently pull out the speaker.
Conclusión
Katie Dunnigan
Miembro Desde 01/24/19
85 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S1-G4, White Winter 2019 Miembro de Cal Poly, Team S1-G4, White Winter 2019
CPSU-WHITE-W19S1G4
4 Miembros
12 Guías creadas
Un comentario
This is awesome but Master & Dynamic don’t sell replacement 45mm 32 ohm drivers and won’t share the specs.
If anyone know where to get a replacement which will work well with these headphones please share!!!
paul
bloodygoose@icloud.com
psullivan_au - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 656
