Saltar al contenido principal
Marvel iHome MR-M66 Power Switch Cover Replacement
Qué necesitas
  1. Marvel iHome MR-M66 Power Switch Cover Replacement, Back Cover: paso 1, imagen 1 de 2 Marvel iHome MR-M66 Power Switch Cover Replacement, Back Cover: paso 1, imagen 2 de 2
    • Remove two of the three screws shown on the bottom of the device.
    • Begin removing the last screw, but leave it partially in the socket to remove the bottom cover easier.
  2. Marvel iHome MR-M66 Power Switch Cover Replacement: paso 2, imagen 1 de 3 Marvel iHome MR-M66 Power Switch Cover Replacement: paso 2, imagen 2 de 3 Marvel iHome MR-M66 Power Switch Cover Replacement: paso 2, imagen 3 de 3
    • Remove the bottom cover by either pulling on the screw or using a plastic opening tool to pry the cover off.
    • After removing the bottom cover, remove the two screws.
  3. Marvel iHome MR-M66 Power Switch Cover Replacement: paso 3, imagen 1 de 3 Marvel iHome MR-M66 Power Switch Cover Replacement: paso 3, imagen 2 de 3 Marvel iHome MR-M66 Power Switch Cover Replacement: paso 3, imagen 3 de 3
    • Use a spudger to release the small retaining clip that holds the feet to the bottom of the device.
    • Be careful here, as too much force can break the clip.
    • Remove the two screws from the back of the device.
  4. Marvel iHome MR-M66 Power Switch Cover Replacement: paso 4, imagen 1 de 3 Marvel iHome MR-M66 Power Switch Cover Replacement: paso 4, imagen 2 de 3 Marvel iHome MR-M66 Power Switch Cover Replacement: paso 4, imagen 3 de 3
    • Using a plastic opening tool and your hand, separate the front and back covers from each other.
    • Starting from the bottom, use the plastic opening tool to create the initial separation and continue along the seam to the top of the device.
    • This step requires the most time and patience, so be careful.
    • The power switch will most likely come loose during this step and you will hear something rattling inside the device.
  5. Marvel iHome MR-M66 Power Switch Cover Replacement: paso 5, imagen 1 de 3 Marvel iHome MR-M66 Power Switch Cover Replacement: paso 5, imagen 2 de 3 Marvel iHome MR-M66 Power Switch Cover Replacement: paso 5, imagen 3 de 3
    • Remove the two arms from either side of the device once a significant separation has been created.
    • They are not fixed to the body itself so you should be able to wiggle them free.
    • Continue pulling the back cover off the device.
    • Remove the red cover for the on/off switch from the device.
Conclusión
Aaram Williams
Miembro Desde 03/08/17
201 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 89
