Saltar al contenido principal
Introducción
The removal of the band is required if you wish to perform a thorough cleaning of the bezel, or if you need to replace the band itself.
Herramientas
Partes
No se especificaron partes.
  1. Take the watch band removal tool and insert it in the small slit between watch bezel and the band, resting up against the bezel.
    • Take the watch band removal tool and insert it in the small slit between watch bezel and the band, resting up against the bezel.
  2. Press down of the shaft that holds the band on, while simultaneously dragging the tip of the tool back towards the band in order to compress the spring bar that holds the band on.
    • Press down of the shaft that holds the band on, while simultaneously dragging the tip of the tool back towards the band in order to compress the spring bar that holds the band on.
    • Drag the tip of the tool away from the bezel while still pressing down in order to remove the shaft from the bezel.
    • The spring shaft may decompress once its out of the bezel and try to shoot away.
  3. Repeat these steps on the other side of the band to completely remove the band, ready for cleaning or replacement.
    • Repeat these steps on the other side of the band to completely remove the band, ready for cleaning or replacement.
Conclusión
Dominic Coffey
Miembro Desde 24/10/16
231 Reputación
2 Guías creadas
Equipo
IUPUI, Team 3-3, Baechle Fall 2016 Miembro de IUPUI, Team 3-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G3
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 195
