Saltar al contenido principal
Introducción
How to access and remove the motherboard of the Martian Smartwatch
  1. Unscrew the four 3.4 mm flat head screws Unscrew the four 3.4 mm flat head screws
    • Unscrew the four 3.4 mm flat head screws
  2. Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
    • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
  3. If not replacing lithium battery, skip down two steps.
    • If not replacing lithium battery, skip down two steps.
    • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
  4. Desolder the battery connections from the motherboard. Learn how to solder components here!
    • Desolder the battery connections from the motherboard. Learn how to solder components here!
  5. Use PH00 screw driver to remove two 2.4mm Phillips head screws.
    • Use PH00 screw driver to remove two 2.4mm Phillips head screws.
  6. Use a spudger or tweezers to remove a white sticker that covers a Phillips head screw.
    • Use a spudger or tweezers to remove a white sticker that covers a Phillips head screw.
  7. Use PH00 screwdriver to remove 5.2mm Phillips head screw
    • Use PH00 screwdriver to remove 5.2mm Phillips head screw
  8. Use ESD safe tweezers to remove the gold ribbon cable. This will expose a second 5.2mm Phillips head screw that can be removed with a PH00 screwdriver. This will expose a second 5.2mm Phillips head screw that can be removed with a PH00 screwdriver.
    • Use ESD safe tweezers to remove the gold ribbon cable.
    • This will expose a second 5.2mm Phillips head screw that can be removed with a PH00 screwdriver.
  9. Use a spudger to gently pry on the motherboard towards the top of the watch, being towards the 12 o'clock position to loosen the motherboard. You can now access the parts and pieces on the bottom of, and below the motherboard.
    • Use a spudger to gently pry on the motherboard towards the top of the watch, being towards the 12 o'clock position to loosen the motherboard.
    • You can now access the parts and pieces on the bottom of, and below the motherboard.
Conclusión
Equipo
IUPUI, Team 3-3, Baechle Fall 2016 Miembro de IUPUI, Team 3-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G3
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 112
