Introducción
Has your Marshall Woburn been having trouble with lower-pitched audio? If so, here is the guide on how to remove the two subwoofers. All you need is the standard #1 Phillips Screwdriver head to remove the screws involved with this replacement.
Qué necesitas
On a flat surface, orient the device so that the front grille is facing downward.
Using a Phillips #1 screwdriver, remove the ten outer 28.6 mm screws marked in red.
Remove the eight inner 28.6 mm screws with the Phillips #1 screwdriver.
Using a Phillips #1 screwdriver, remove the eight 15.8 mm screws attaching the subwoofers to the frame.
