Introducción
Are you having trouble connecting your devices to the back of your Marshall Woburn? If so, here is the guide on how to take out the back input board. All you need is the standard #1 Phillips Screwdriver head to remove the screws involved with this replacement.
Qué necesitas
On a flat surface, orient the device so that the front grille is facing downward.
Using a Phillips #1 screwdriver, remove the ten outer 28.6 mm screws marked in red.
Remove the eight inner 28.6 mm screws with the Phillips #1 screwdriver.
Un comentario
what is step 7? Replace the board? PS. I was born in N Dartmouth!
