Saltar al contenido principal
Marshall Uxbridge LinkPlay Board Replacement
Qué necesitas
  1. Marshall Uxbridge LinkPlay Board Replacement, Back Panel: paso 1, imagen 1 de 3 Marshall Uxbridge LinkPlay Board Replacement, Back Panel: paso 1, imagen 2 de 3 Marshall Uxbridge LinkPlay Board Replacement, Back Panel: paso 1, imagen 3 de 3
    • Orient your speaker so that the back is facing you.
    • Use a Phillips #2 screwdriver to remove the six 19mm screws from the back plate.
    • Use an iFixit opening pick to remove and lift the back plate to expose the connected wires.
  2. Marshall Uxbridge LinkPlay Board Replacement: paso 2, imagen 1 de 2 Marshall Uxbridge LinkPlay Board Replacement: paso 2, imagen 2 de 2
    • Detach the white connector from inside the bottom of the back panel.
    • Detach the small red and white connectors from the motherboard on the left side of the back panel.
  3. Marshall Uxbridge LinkPlay Board Replacement: paso 3, imagen 1 de 1
    • Pull the blue ribbon cables from the motherboard.
    • Remove the back panel from the speaker base.
  4. Marshall Uxbridge LinkPlay Board Replacement, Motherboard: paso 4, imagen 1 de 2 Marshall Uxbridge LinkPlay Board Replacement, Motherboard: paso 4, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the six 12 mm screws from the motherboard.
  5. Marshall Uxbridge LinkPlay Board Replacement: paso 5, imagen 1 de 1
    • Use a Phillips #000 screwdriver to remove the two 6 mm black screws holding the black board that says "LinkPlay" in place.
  6. Marshall Uxbridge LinkPlay Board Replacement: paso 6, imagen 1 de 2 Marshall Uxbridge LinkPlay Board Replacement: paso 6, imagen 2 de 2
    • Use a TR 6 Torx screwdriver to remove the two silver 6 mm screws from the LinkPlay board.
  7. Marshall Uxbridge LinkPlay Board Replacement: paso 7, imagen 1 de 2 Marshall Uxbridge LinkPlay Board Replacement: paso 7, imagen 2 de 2
    • Lift the motherboard.
    • Slide the LinkPlay board down to remove the motherboard from the back panel.
  8. Marshall Uxbridge LinkPlay Board Replacement, LinkPlay Board: paso 8, imagen 1 de 2 Marshall Uxbridge LinkPlay Board Replacement, LinkPlay Board: paso 8, imagen 2 de 2
    • Detach the two antennas that connect the LinkPlay to the speaker's back panel.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 10
Ultimos 30 días: 37
Todo El Tiempo: 75
