Saltar al contenido principal
Marshall Emberton Motherboard Replacement
Qué necesitas
  1. Marshall Emberton Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • In order to start uncrewing any of the screws off the speaker we have to peel the protective cover off.
  2. Marshall Emberton Motherboard Replacement: paso 2, imagen 1 de 1
    • Pry the front of the speaker off using your nails or a device capable of fitting inside the crevice.
  3. Marshall Emberton Motherboard Replacement: paso 3, imagen 1 de 1
    • Once pried off, we have to remove the eight 1.2 cm screws on the speaker.
    • Use a TR9 screwdriver for the screws.
  4. Marshall Emberton Motherboard Replacement: paso 4, imagen 1 de 1
    • There are six more 1.2cm screws required to remove in order to take out the motherboard.
  5. Marshall Emberton Motherboard Replacement: paso 5, imagen 1 de 2 Marshall Emberton Motherboard Replacement: paso 5, imagen 2 de 2
    • You then need to unplug all three wires connected to the motherboard.
Conclusión
Una persona más ha completado esta guía.
Asia Baldwin
Miembro Desde 09/26/22
697 Reputación
5 Guías creadas
Equipo
CSU Los Angeles, Team 5-1, Adachi Fall 2022 Miembro de CSU Los Angeles, Team 5-1, Adachi Fall 2022
CSULA-ADACHI-F22S5G1
5 Miembros
5 Guías creadas
Un comentario
How or where can I purchase a new motherboard for my Emberton II? My won’t charge the battery any longer, I’ve since bought another speaker but would like to repair this one if I can get my hands on a new motherboard. Thanks in advance.
jeremy a bolduc - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 12
Ultimos 30 días: 66
Todo El Tiempo: 920
