Saltar al contenido principal
Marshall Emberton Main Speaker Replacement
Qué necesitas
  1. Marshall Emberton Main Speaker Replacement, Main Speaker: paso 1, imagen 1 de 1
    • Remove the rubber casing from the speaker by peeling it off using your nails.
  2. Marshall Emberton Main Speaker Replacement: paso 2, imagen 1 de 1
    • Pry the front of the speaker that says "Marshall" in order to get inside the speaker.
  3. Marshall Emberton Main Speaker Replacement: paso 3, imagen 1 de 1
    • Remove the eight 1.2 cm screws using a TR9 screwdriver.
  4. Marshall Emberton Main Speaker Replacement: paso 4, imagen 1 de 1
    • Now pop the speaker out and remove the entire piece.
  5. Marshall Emberton Main Speaker Replacement: paso 5, imagen 1 de 1
    • Now you must disconnect two wire connectors, by firmly tugging on the wires.
    • The new speakers can now be connected and put back together.
Conclusión
Asia Baldwin
Miembro Desde 09/26/22
697 Reputación
5 Guías creadas
Equipo
CSU Los Angeles, Team 5-1, Adachi Fall 2022 Miembro de CSU Los Angeles, Team 5-1, Adachi Fall 2022
CSULA-ADACHI-F22S5G1
5 Miembros
5 Guías creadas
Un comentario
Hi! Where from can I by the speakers? pls help
Cristian MUNTEANU - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 21
Ultimos 30 días: 102
Todo El Tiempo: 2,328
