Saltar al contenido principal
Manual recalibration
  1. Manual recalibration, Manual recalibration: paso 1, imagen 1 de 1
    • Open the Thrustmaster Control panel application and set the angle to 1080°
    • If you are using PlayStation, manually set rotation angle to 1080°
    • Unplug and re-plug T-GT II to USB port.
    • Wait for auto-calibration to finish
  2. Manual recalibration, Steer the wheel all the way to the left: paso 3, imagen 1 de 1
    • Keep turning the wheel until you reach a physical stop
  3. Manual recalibration, Steer the wheel all the way to the right: paso 4, imagen 1 de 1
  4. Manual recalibration, Center your wheel: paso 5, imagen 1 de 1
    • Perfectly center your wheel.
    • Keep in mind that rotation is set to 1080°.
  5. Manual recalibration, Press the indicated buttons: paso 6, imagen 1 de 1
    • Press SHARE + OPTIONS + MODE buttons at the same time.
    • LED will flash if successful.
    • If you are using a different wheel, then a button combination will be different. You can find button combination list here.
Linea de Meta
Formica Fusca
Miembro Desde 08/01/24
2,587 Reputación
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 30
Todo El Tiempo: 141
