Saltar al contenido principal
Makita XPH01 Gear Select Switch Replacement
Qué necesitas
  1. Makita XPH01 Gear Select Switch Replacement, Outer Casing: paso 1, imagen 1 de 2 Makita XPH01 Gear Select Switch Replacement, Outer Casing: paso 1, imagen 2 de 2
    • Hold the drill upright with the back panel facing you.
    • Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
  2. Makita XPH01 Gear Select Switch Replacement: paso 2, imagen 1 de 1
    • Apply slight pressure to the sides of the backplate and pull away from the drill.
  3. Makita XPH01 Gear Select Switch Replacement: paso 3, imagen 1 de 2 Makita XPH01 Gear Select Switch Replacement: paso 3, imagen 2 de 2
    • Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
  4. Makita XPH01 Gear Select Switch Replacement: paso 4, imagen 1 de 2 Makita XPH01 Gear Select Switch Replacement: paso 4, imagen 2 de 2
    • Apply slight pressure to the sides of the outer casing and pull away from the drill.
  5. Makita XPH01 Gear Select Switch Replacement, Gear Select Switch: paso 5, imagen 1 de 1
    • Pull the silver metal clip located towards the back of drill away from the motor assembly.
  6. Makita XPH01 Gear Select Switch Replacement: paso 6, imagen 1 de 2 Makita XPH01 Gear Select Switch Replacement: paso 6, imagen 2 de 2
    • Gently grip the front of the motor assembly and pull it out of the plastic casing.
    • The wires are still connected to the back of the motor assembly, so use caution when pulling the motor out. Failing to do this will result in parts falling off the back of the motor
  7. Makita XPH01 Gear Select Switch Replacement: paso 7, imagen 1 de 2 Makita XPH01 Gear Select Switch Replacement: paso 7, imagen 2 de 2
    • Push gear select switch forward.
    • Lift the gear select switch to separate it from the motor assembly.
Conclusión
3 personas más completaron esta guía.
Eric Herwatt
Miembro Desde 10/05/16
963 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 15-4, Livingston Fall 2016 Miembro de Cal Poly, Team 15-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G4
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 1,188
