Saltar al contenido principal
Makita XPH01 Forward/Reverse Switch Replacement
Qué necesitas
  1. Makita XPH01 Forward/Reverse Switch Replacement, Battery: paso 1, imagen 1 de 1
    • Hold the drill upright.
    • Place your finger on the white battery-release button.
  2. Makita XPH01 Forward/Reverse Switch Replacement: paso 2, imagen 1 de 1
    • Press and hold the white release button located on the front of the battery.
  3. Makita XPH01 Forward/Reverse Switch Replacement: paso 3, imagen 1 de 1
    • Slide the battery forward while pressing down on the white battery-release button.
  4. Makita XPH01 Forward/Reverse Switch Replacement, Outer Casing: paso 4, imagen 1 de 2 Makita XPH01 Forward/Reverse Switch Replacement, Outer Casing: paso 4, imagen 2 de 2
    • Hold the drill upright with the back panel facing you.
    • Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
  5. Makita XPH01 Forward/Reverse Switch Replacement: paso 5, imagen 1 de 1
    • Apply slight pressure to the sides of the backplate and pull away from the drill.
  6. Makita XPH01 Forward/Reverse Switch Replacement: paso 6, imagen 1 de 2 Makita XPH01 Forward/Reverse Switch Replacement: paso 6, imagen 2 de 2
    • Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
  7. Makita XPH01 Forward/Reverse Switch Replacement: paso 7, imagen 1 de 2 Makita XPH01 Forward/Reverse Switch Replacement: paso 7, imagen 2 de 2
    • Apply slight pressure to the sides of the outer casing and pull away from the drill.
  8. Makita XPH01 Forward/Reverse Switch Replacement, Forward/Reverse Switch: paso 8, imagen 1 de 1
    • Pull the black trigger assembly away from the drill.
  9. Makita XPH01 Forward/Reverse Switch Replacement: paso 9, imagen 1 de 2 Makita XPH01 Forward/Reverse Switch Replacement: paso 9, imagen 2 de 2
    • Grab onto the forward/reverse switch.
    • Gently pull the forward/reverse switch to separate it from the trigger assembly.
Conclusión
2 personas más completaron esta guía.
Eric Herwatt
Miembro Desde 10/05/16
984 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 15-4, Livingston Fall 2016 Miembro de Cal Poly, Team 15-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G4
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 52
Todo El Tiempo: 5,921
