Saltar al contenido principal
Makita XPH01 Drill Brush Replacement
Qué necesitas
  1. Makita XPH01 Drill Brush Replacement, Battery: paso 1, imagen 1 de 1
    • Hold the drill upright.
    • Place your finger on the white battery-release button.
  2. Makita XPH01 Drill Brush Replacement: paso 2, imagen 1 de 1
    • Press and hold the white release button located on the front of the battery.
  3. Makita XPH01 Drill Brush Replacement: paso 3, imagen 1 de 1
    • Slide the battery forward while pressing down on the white battery-release button.
  4. Makita XPH01 Drill Brush Replacement, Drill Brush: paso 4, imagen 1 de 1
    • Hold the drill upright with the back panel facing you.
  5. Makita XPH01 Drill Brush Replacement: paso 5, imagen 1 de 2 Makita XPH01 Drill Brush Replacement: paso 5, imagen 2 de 2
    • Unscrew two 18mm screws from the back panel with the Phillips PH2 screwdriver.
  6. Makita XPH01 Drill Brush Replacement: paso 6, imagen 1 de 2 Makita XPH01 Drill Brush Replacement: paso 6, imagen 2 de 2
    • Apply slight pressure to the sides of the backplate and pull away from the drill.
  7. Makita XPH01 Drill Brush Replacement: paso 7, imagen 1 de 3 Makita XPH01 Drill Brush Replacement: paso 7, imagen 2 de 3 Makita XPH01 Drill Brush Replacement: paso 7, imagen 3 de 3
    • Hold the drill so the back end is facing toward you.
    • Use the spudger to lift the spring clip out of the back notch.
    • Pull the spring clip forward and rest it in the front notch.
  8. Makita XPH01 Drill Brush Replacement: paso 8, imagen 1 de 2 Makita XPH01 Drill Brush Replacement: paso 8, imagen 2 de 2
    • Use the tweezers to pull the drill brush away from the sleeve.
  9. Makita XPH01 Drill Brush Replacement: paso 9, imagen 1 de 3 Makita XPH01 Drill Brush Replacement: paso 9, imagen 2 de 3 Makita XPH01 Drill Brush Replacement: paso 9, imagen 3 de 3
    • Use the plastic opening tool to release the clip connected to the drill brush.
    • Separate the drill brush away from the clip.
Conclusión
3 personas más completaron esta guía.
Eric Herwatt
Miembro Desde 10/05/16
984 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 15-4, Livingston Fall 2016 Miembro de Cal Poly, Team 15-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G4
4 Miembros
7 Guías creadas
Un comentario
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 20
Todo El Tiempo: 5,836
