Saltar al contenido principal
Makita GA4030K Armature Replacement
Qué necesitas
  1. Makita GA4030K Armature Replacement, Disk Cover: paso 1, imagen 1 de 1
    • Check for the provided lock nut wrench. This is used for loosening the piece that keeps the disk and cover attached.
  2. Makita GA4030K Armature Replacement: paso 2, imagen 1 de 1
    • Unscrew the handle unit until it is removed completely.
  3. Makita GA4030K Armature Replacement: paso 3, imagen 1 de 2 Makita GA4030K Armature Replacement: paso 3, imagen 2 de 2
    • Hold the black switch located on the front casing.
    • Still holding the switch, use the lock nut wrench to loosen the silver disk holding everything in place.
    • Once loose, remove the silver disk and/or your grinding disk.
  4. Makita GA4030K Armature Replacement: paso 4, imagen 1 de 2 Makita GA4030K Armature Replacement: paso 4, imagen 2 de 2
    • Use a Phillips #02 screwdriver to remove the 15 mm pan head screw that holds the cover in place.
    • Remove the cover by lining up the knob on the cover with the notch in face plate.
  5. Makita GA4030K Armature Replacement, Back Cover: paso 5, imagen 1 de 2 Makita GA4030K Armature Replacement, Back Cover: paso 5, imagen 2 de 2
    • Unscrew the 20 mm tapping screw using a Philips #02 screwdriver.
  6. Makita GA4030K Armature Replacement: paso 6, imagen 1 de 1
    • Slide the back cover down the power cable.
  7. Makita GA4030K Armature Replacement, Armature: paso 7, imagen 1 de 2 Makita GA4030K Armature Replacement, Armature: paso 7, imagen 2 de 2
    • Use a spudger to gently move the brush holder coil to the side.
    • There are two brushes that are secured by two separate brush holders, one on each side.
  8. Makita GA4030K Armature Replacement: paso 8, imagen 1 de 2 Makita GA4030K Armature Replacement: paso 8, imagen 2 de 2
    • Using a metal spudger, remove both carbon brushes (one on each side) by their copper cabling.
  9. Makita GA4030K Armature Replacement: paso 9, imagen 1 de 3 Makita GA4030K Armature Replacement: paso 9, imagen 2 de 3 Makita GA4030K Armature Replacement: paso 9, imagen 3 de 3
    • Use a Phillips #2 screwdriver to remove the four 20 mm tapping screws that hold the armature assembly in place.
    • Remove the armature assembly
  10. Makita GA4030K Armature Replacement: paso 10, imagen 1 de 2 Makita GA4030K Armature Replacement: paso 10, imagen 2 de 2
    • Unscrew the four 10 mm tapping screws holding the faceplate using a Phillips #02 screwdriver.
    • Remove the faceplate.
  11. Makita GA4030K Armature Replacement: paso 11, imagen 1 de 2 Makita GA4030K Armature Replacement: paso 11, imagen 2 de 2
    • Hold the highlighted nut with a size 10 wrench. Unscrew by turning the armature and holding the nut in place.
    • The nut may be difficult to remove.
  12. Makita GA4030K Armature Replacement: paso 12, imagen 1 de 1
    • Remove the armature.
Conclusión
5 personas más completaron esta guía.
Equipo
Cal Poly, Team 12-5, Lancaster Spring 2015 Miembro de Cal Poly, Team 12-5, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G5
4 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 3,460
