Saltar al contenido principal
Making Visible the Users Library Directory in OS X Lion
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. Making Visible the Users Library Directory in OS X Lion, Making Visible the Users Library Directory in OS X Lion: paso 1, imagen 1 de 2 Making Visible the Users Library Directory in OS X Lion, Making Visible the Users Library Directory in OS X Lion: paso 1, imagen 2 de 2
    • Many Macintosh users were excited when OS X 10.7 (Lion) was released, but after using it for a short time, many users realized that something was missing from lion.
    • The users Library directory is not where it it should be, infact, it is nowhere to be found. Fortunately, it is very simple to bring back the disappearing Library.
  2. Making Visible the Users Library Directory in OS X Lion: paso 2, imagen 1 de 1
    • To begin the process, you will need to go to your Applications folder, which can be found in your Finder side bar.
    • Once in the Applications folder, you will want to find the Utilities folder.
  3. Making Visible the Users Library Directory in OS X Lion: paso 3, imagen 1 de 1
    • After navigating to the Utilities folder you will need to scroll down to find the Terminal application.
  4. Making Visible the Users Library Directory in OS X Lion: paso 4, imagen 1 de 2 Making Visible the Users Library Directory in OS X Lion: paso 4, imagen 2 de 2
    • Once you have opened Terminal, you will need to type chflags nohidden ~/Library/ and then press Enter.
    • This will immediately make your Library folder visible under your user.
  5. Making Visible the Users Library Directory in OS X Lion: paso 5, imagen 1 de 1
    • Once you have finished with Terminal, type exit to end your terminal processes. After you have typed this and hit enter you may quit out of Terminal.
  6. Making Visible the Users Library Directory in OS X Lion: paso 6, imagen 1 de 1
    • To hide the Library folder, simply type chflags hidden ~/Library and press Enter.
    • Remember to type exit and press Enter before quitting Terminal.
Conclusión
Una persona más ha completado esta guía.
Owen Cunneely
Miembro Desde 12/01/10
7,127 Reputación
1 Guía escrita
Equipo
Master Techs Miembro de Master Techs
Community
321 Miembros
1,464 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 12
Todo El Tiempo: 1,399
