Saltar al contenido principal
Maisto Rock Crawler Remote Circuit Board Replacement
Qué necesitas
  1. Maisto Rock Crawler Remote Circuit Board Replacement, Remote Circuit Board: paso 1, imagen 1 de 1
    • Remove the batteries before doing anything.
    • Use the driver and bit J1 to remove the five 9.5mm Philips screws holding the remote together.
  2. Maisto Rock Crawler Remote Circuit Board Replacement: paso 2, imagen 1 de 1
    • Take off the half of the remote that had the screw heads facing up.
  3. Maisto Rock Crawler Remote Circuit Board Replacement: paso 3, imagen 1 de 1
    • Slide out the circuit board.
    • Use the soldering iron to desolder the 3 wires.
Conclusión
5 personas más completaron esta guía.
kevin
Miembro Desde 02/10/16
874 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 1-2, Sullivan Spring 2016 Miembro de USF Tampa, Team 1-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G2
3 Miembros
6 Guías creadas
5 comentarios
Can you show the wheel controller mechanism. I can see 3 contacts on mine but I think mine is missing something that would bring the contacts together as you turn the wheel to steer left and right. Thanks.
Ferdinand Fong - Contestar
the triger is broken to drive the truck
joey heller - Contestar
Somebody have the remote control for
Theodore Brock - Contestar
I have a 1970 R/T charger RC car, 2.4GHz, I changed it up fully, but the pairing light wont come on. But I can show the lights,the control power is good.what is wrong can anybody help me find the problem and fix it.
Keith Pryor - Contestar
How to pair new controller ?
Karel Říha - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 34
Todo El Tiempo: 4,603
