Saltar al contenido principal
Maisto Rock Crawler Rear Axle Replacement
Qué necesitas
  1. Maisto Rock Crawler Rear Axle Replacement, Rear Axle: paso 1, imagen 1 de 1
    • Flip the R/C truck over.
    • To take off the R/C truck top, use the driver and bit PH2 and remove the four 7.7 mm Phillips screws highlighted.
  2. Maisto Rock Crawler Rear Axle Replacement: paso 2, imagen 1 de 1
    • Half way remove the truck top so you can unhinge the antenna from the clips.
    • Remove the R/C truck top completely.
  3. Maisto Rock Crawler Rear Axle Replacement: paso 3, imagen 1 de 1
    • Use the Driver and bit J1 to remove the top under-body plate by unscrewing the eight 9.5 mm Phillips screws.
  4. Maisto Rock Crawler Rear Axle Replacement: paso 4, imagen 1 de 1
    • After removing the plate use the driver and bit J1 to unscrew the two 9.5 mm Phillips screws that hold the side circuit board in.
  5. Maisto Rock Crawler Rear Axle Replacement: paso 5, imagen 1 de 1
    • Flip the R/C truck over and remove the four 10 mm bottom under-body plate screws using the driver and bit PH2.
  6. Maisto Rock Crawler Rear Axle Replacement: paso 6, imagen 1 de 1
    • Flip the R/C truck over again.
    • Remember which wire is connected at which pin before desoldering.
    • Desolder the 2 wires connected from the rear axle to the circuit board.
  7. Maisto Rock Crawler Rear Axle Replacement: paso 7, imagen 1 de 1
    • You can refer to the tire replacement guide to keep salvageable tires from the removed axle.
Conclusión
Una persona más ha completado esta guía.
kevin
Miembro Desde 02/10/16
874 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 1-2, Sullivan Spring 2016 Miembro de USF Tampa, Team 1-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G2
3 Miembros
6 Guías creadas
2 comentarios
Nice guide. Do you know where to buy parts for the repairment? I have searched all over but cannot seem to find any parts.
martinrene - Contestar
Your best bet is a hobby shop I haven't seen any online sources myself
kevin - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 2,437
