Saltar al contenido principal
Magnavox MWD200F Disk Drive Replacement
Qué necesitas
  1. Magnavox MWD200F Disk Drive Replacement, Faceplate: paso 1, imagen 1 de 1
    • Use a Phillips #2 screwdriver to remove the two screws on the top of the device toward the back.
  2. Magnavox MWD200F Disk Drive Replacement: paso 2, imagen 1 de 1
    • Remove the plastic cover by lifting up the back and pulling it away from the faceplate.
  3. Magnavox MWD200F Disk Drive Replacement: paso 3, imagen 1 de 1
    • Unclip the three latches on the bottom of the device.
  4. Magnavox MWD200F Disk Drive Replacement: paso 4, imagen 1 de 1
    • Pull the faceplate off.
  5. Magnavox MWD200F Disk Drive Replacement, Disk Drive: paso 5, imagen 1 de 2 Magnavox MWD200F Disk Drive Replacement, Disk Drive: paso 5, imagen 2 de 2
    • Use a Phillips #2 screwdriver to remove the two screws at the base of the disk drive.
  6. Magnavox MWD200F Disk Drive Replacement: paso 6, imagen 1 de 2 Magnavox MWD200F Disk Drive Replacement: paso 6, imagen 2 de 2
    • Use the screwdriver to remove two screws on either side of the silver security bar.
  7. Magnavox MWD200F Disk Drive Replacement: paso 7, imagen 1 de 2 Magnavox MWD200F Disk Drive Replacement: paso 7, imagen 2 de 2
    • Pull out the silver security bar and set aside.
  8. Magnavox MWD200F Disk Drive Replacement: paso 8, imagen 1 de 1
    • Take out the two screws on either side of the green circuit board.
  9. Magnavox MWD200F Disk Drive Replacement: paso 9, imagen 1 de 2 Magnavox MWD200F Disk Drive Replacement: paso 9, imagen 2 de 2
    • Carefully lift the board just enough to remove the disk drive.
  10. Magnavox MWD200F Disk Drive Replacement: paso 10, imagen 1 de 3 Magnavox MWD200F Disk Drive Replacement: paso 10, imagen 2 de 3 Magnavox MWD200F Disk Drive Replacement: paso 10, imagen 3 de 3
    • Remove the two screws at the back of the disk drive.
  11. Magnavox MWD200F Disk Drive Replacement: paso 11, imagen 1 de 2 Magnavox MWD200F Disk Drive Replacement: paso 11, imagen 2 de 2
    • Gently lift the disk drive out of the DVD player.
    • The disk drive is still attached but you are now able to get to underneath it for cleaning and maintenance.
Conclusión
Taryn
Miembro Desde 09/15/11
109 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 1,490
