Introducción
While some people like the tap-to-click feature of the Magic Trackpad, other users, such as myself, prefer a click that we can feel. After months of use, sometimes the trackpad will get stuck and will no longer click in on one side or the other. This repair guide will have your Magic Trackpad clicking again in under 5 minutes.
Qué necesitas
Get your Magic Trackpad out and prepare to fix it.
Unscrew the battery door by turning the screw counter-clockwise with a flat edge screwdriver, coin, plastic opening tool, or fingernail.
Remove the batteries to prevent any short-circuiting while fixing your Magic Trackpad.
Use a T-6 or T-7 Torx bit to adjust the tightness of the little screw highlighted in red in the bottom-left corner of the device (top-down).
If the right click works but the left click doesn't, you'll need to turn the screw clockwise.
Note: right and left clicks are determined by the Trackpad top, not the view from the bottom as you are adjust the screw.
If neither the right click nor left click work, turn it counter-clockwise if there is no movement at all, and clockwise if there is movement but it is too soft to click.
112 personas más completaron esta guía.
81 comentarios
DO NOT DO THIS! My trackpad had the central chip glued STRONGLY to the plastic piece. Pulling off the plastic plate ripped the chip right off. My trackpad is now completely dead. I repeat: DO NOT DO THIS FIX! Your trackpad might not be glued, but I have ruined this thing.
Chris, I just did the same thing to mine and had the same result. I wish I'd read your warning first! Perhaps some heat at the center of the plastic backing would have helped release the adhesive from the chip/backing.
To anyone attempting this fix, if you feel anything in the center of the plastic back cover sticking, do not force it off. It might be possible to get a blade in there to slice through the adhesive, but it really didn't take much force at all for the chip to break free of the circuit board.
David -
I have updated the guide with your warning. I would recommend in the future not pulling anythng apart that could cause ripping. You'll notice the original instructions recommending cutting through the glue, not ripping it apart. Those recommendations were from a breakdown guide and have worked for multiple users. I myself have repaired trackpads 3-4 times following the above instructions.
I have also updated the difficulty to moderate from easy.
