Saltar al contenido principal
Magic Bullet NutriBullet Outside Casing Replacement
Qué necesitas
  1. Magic Bullet NutriBullet Outside Casing Replacement, Curve Base: paso 1, imagen 1 de 1
    • Unplug the device from the wall and turn the powerbase upside down.
  2. Magic Bullet NutriBullet Outside Casing Replacement: paso 2, imagen 1 de 2 Magic Bullet NutriBullet Outside Casing Replacement: paso 2, imagen 2 de 2
    • Use a #2 Phillips Head Screwdriver to unscrew the four 10 mm screws located on the bottom of the power base.
  3. Magic Bullet NutriBullet Outside Casing Replacement: paso 3, imagen 1 de 1
    • Use slight tension to remove the plastic base from the NutriBullet once all of the screws are removed.
    • Once the plastic base is removed, there is a fan located in the center of the powerbase. Make sure the cord does not get caught or frayed by the fan.
  4. Magic Bullet NutriBullet Outside Casing Replacement: paso 4, imagen 1 de 1
    • Lift the power cord to remove it from the side slot on the curved base.
  5. Magic Bullet NutriBullet Outside Casing Replacement: paso 5, imagen 1 de 2 Magic Bullet NutriBullet Outside Casing Replacement: paso 5, imagen 2 de 2
    • Use a #2 Phillips Head Screwdriver to remove the two 10 mm screws that secure the white bracket down.
    • The white safety bracket holds the cord down. After removing it, the cord will be loosened.
  6. Magic Bullet NutriBullet Outside Casing Replacement: paso 6, imagen 1 de 1
    • Use a #2 Phillips Head Screwdriver to remove the three 10mm screws that keep the base in place.
  7. Magic Bullet NutriBullet Outside Casing Replacement: paso 7, imagen 1 de 1
    • Use slight tension to remove the curved base by lifting it upward off of the outside casing.
  8. Magic Bullet NutriBullet Outside Casing Replacement, Outside Casing: paso 8, imagen 1 de 1
    • Wiggle the outside casing upward until it separates from the powerbase.
    • Hold the ring at the bottom of the powerbase to receive a better grip.
Conclusión
5 personas más completaron esta guía.
Angela Wong
Miembro Desde 01/22/15
1,072 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 19-8, Maness Winter 2015 Miembro de Cal Poly, Team 19-8, Maness Winter 2015
CPSU-MANESS-W15S19G8
4 Miembros
7 Guías creadas
2 comentarios
Ok so what happens after Step 8 of pulling the Nutribullet apart? Did I miss something?? Now I have my Nutribullet in pieces on the benchtop. Now what??
Nicole Corse-Scott - Contestar
Same problem. I can't get the drive gear on the top loose which I assume will actual give me access to the wiring. I am guessing it is a pressure fit but I can't get anything under it to pry it loose. If it is a screw attachment don't want to break it. Help.
rjurgena - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 31
Todo El Tiempo: 7,110
