Saltar al contenido principal
Magic Bullet NutriBullet Curve Base
Qué necesitas
  1. Magic Bullet NutriBullet Curve Base, Curve Base: paso 1, imagen 1 de 1
    • Unplug the device from the wall and turn the powerbase upside down.
  2. Magic Bullet NutriBullet Curve Base: paso 2, imagen 1 de 2 Magic Bullet NutriBullet Curve Base: paso 2, imagen 2 de 2
    • Use a #2 Phillips Head Screwdriver to unscrew the four 10 mm screws located on the bottom of the power base.
  3. Magic Bullet NutriBullet Curve Base: paso 3, imagen 1 de 1
    • Use slight tension to remove the plastic base from the NutriBullet once all of the screws are removed.
    • When reassembling, note the fan located in the center of the powerbase. Make sure the cord does not get caught or frayed by the fan.
  4. Magic Bullet NutriBullet Curve Base: paso 4, imagen 1 de 1
    • Lift the power cord to remove it from the side slot on the curved base.
  5. Magic Bullet NutriBullet Curve Base: paso 5, imagen 1 de 2 Magic Bullet NutriBullet Curve Base: paso 5, imagen 2 de 2
    • Use a #2 Phillips Head Screwdriver to remove the two 10 mm screws that secure the white bracket down.
    • The white safety bracket holds the cord down. After removing it, the cord will be loosened.
  6. Magic Bullet NutriBullet Curve Base: paso 6, imagen 1 de 1
    • Use a #2 Phillips Head Screwdriver to remove the three 10mm screws that keep the base in place.
  7. Magic Bullet NutriBullet Curve Base: paso 7, imagen 1 de 1
    • Use slight tension to remove the curved base by lifting it upward off of the outside casing.
Conclusión
Una persona más ha completado esta guía.
Geary Yu
Miembro Desde 01/22/15
1,208 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 19-8, Maness Winter 2015 Miembro de Cal Poly, Team 19-8, Maness Winter 2015
CPSU-MANESS-W15S19G8
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 30
Todo El Tiempo: 4,027
