Saltar al contenido principal
Magic Bullet NutriBullet Base Replacement
Qué necesitas
  1. Magic Bullet NutriBullet Base Replacement, Base: paso 1, imagen 1 de 1
    • Unplug the device from the wall and turn the powerbase upside down.
  2. Magic Bullet NutriBullet Base Replacement: paso 2, imagen 1 de 2 Magic Bullet NutriBullet Base Replacement: paso 2, imagen 2 de 2
    • Unscrew the four 10mm screws located on the bottom of the powerbase using the Phillips Head #2 Screwdriver.
  3. Magic Bullet NutriBullet Base Replacement: paso 3, imagen 1 de 1
    • Once the screws are removed, use slight tension to pull the plastic base up.
    • Make sure the cord does not get caught or frayed by the fan, which is located in the center of the power base.
Conclusión
3 personas más completaron esta guía.
Angela Wong
Miembro Desde 01/22/15
1,156 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 19-8, Maness Winter 2015 Miembro de Cal Poly, Team 19-8, Maness Winter 2015
CPSU-MANESS-W15S19G8
Miembros de 4
13 Guías creadas
3Guía Comentarios
So far it was easy! Yeah!
Elaine - Contestar
With a lot of force can’t get bottom of even 4 screws removed Bullet don’t work anymore may be a piece of junk now
Tommy Simpson - Contestar
Where can you buy the base to replace?
Anne-Christine von Wetter - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 40
Todo El Tiempo: 10,381
