Saltar al contenido principal
Magic Bullet MB1001B Power Cord Replacement
Qué necesitas
  1. Magic Bullet MB1001B Power Cord Replacement, Power Cord: paso 1, imagen 1 de 1
    • Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
  2. Magic Bullet MB1001B Power Cord Replacement: paso 2, imagen 1 de 1
    • Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
  3. Magic Bullet MB1001B Power Cord Replacement: paso 3, imagen 1 de 1
    • Remove the black base plate.
  4. Magic Bullet MB1001B Power Cord Replacement: paso 4, imagen 1 de 1
    • Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
  5. Magic Bullet MB1001B Power Cord Replacement: paso 5, imagen 1 de 1
    • Remove the white plastic cable guide.
  6. Magic Bullet MB1001B Power Cord Replacement: paso 6, imagen 1 de 1
    • Remove the two crimp caps from the end of the wires.
    • You will need to purchase new crimp caps and use pliers to crimp the new crimp caps on the connected wires during reassembly.
  7. Magic Bullet MB1001B Power Cord Replacement: paso 7, imagen 1 de 1
    • Separate the black wires of the power cord from the red wires on the Magic Bullet base.
    • Be sure to mark which wires are connected before separating them to ensure that they are properly reconnected during reassembly.
Conclusión
2 personas más completaron esta guía.
Bridget Carr
Miembro Desde 10/06/15
266 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 12-13, Maness Fall 2015 Miembro de Cal Poly, Team 12-13, Maness Fall 2015
CPSU-MANESS-F15S12G13
4 Miembros
8 Guías creadas
2 comentarios
I accidentally burnt through my power cord. What type of power cord do I need to replace it?
virginia.cooke - Contestar
Where do we get a new power cord, and if that does not work, what do we do next?
davidcohnkettlebells - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 35
Todo El Tiempo: 2,388
