Saltar al contenido principal
Magellan Roadmate 9055-LM Touchscreen Replacement
Qué necesitas
  1. Magellan Roadmate 9055-LM Touchscreen Replacement, Magellan Roadmate 9055-LM Back Panel Disassembly: paso 1, imagen 1 de 1
    • Flip your device with back panel facing up.
  2. Magellan Roadmate 9055-LM Touchscreen Replacement: paso 2, imagen 1 de 3 Magellan Roadmate 9055-LM Touchscreen Replacement: paso 2, imagen 2 de 3 Magellan Roadmate 9055-LM Touchscreen Replacement: paso 2, imagen 3 de 3
    • Unscrew four Phillips #0 screws from the back panel.
  3. Magellan Roadmate 9055-LM Touchscreen Replacement: paso 3, imagen 1 de 2 Magellan Roadmate 9055-LM Touchscreen Replacement: paso 3, imagen 2 de 2
    • Unscrew two Phillips #0 screws from the back panel.
  4. Magellan Roadmate 9055-LM Touchscreen Replacement: paso 4, imagen 1 de 2 Magellan Roadmate 9055-LM Touchscreen Replacement: paso 4, imagen 2 de 2
    • Use a plastic opening tool to pop the right side of the panel.
  5. Magellan Roadmate 9055-LM Touchscreen Replacement: paso 5, imagen 1 de 1
    • Lifting the back panel too quickly or forcefully may damage the speaker cable and battery cable, which are still attached underneath.
    • Gently lift up the back panel.
  6. Magellan Roadmate 9055-LM Touchscreen Replacement: paso 6, imagen 1 de 3 Magellan Roadmate 9055-LM Touchscreen Replacement: paso 6, imagen 2 de 3 Magellan Roadmate 9055-LM Touchscreen Replacement: paso 6, imagen 3 de 3
    • Remove the tape.
    • Unplug the cable for the speaker.
  7. Magellan Roadmate 9055-LM Touchscreen Replacement: paso 7, imagen 1 de 3 Magellan Roadmate 9055-LM Touchscreen Replacement: paso 7, imagen 2 de 3 Magellan Roadmate 9055-LM Touchscreen Replacement: paso 7, imagen 3 de 3
    • Remove the cable of the battery.
    • Tape removal is not necessary.
  8. Magellan Roadmate 9055-LM Touchscreen Replacement: paso 8, imagen 1 de 1
    • Place the back panel gently on the table.
  9. Magellan Roadmate 9055-LM Touchscreen Replacement, Motherboard: paso 9, imagen 1 de 2 Magellan Roadmate 9055-LM Touchscreen Replacement, Motherboard: paso 9, imagen 2 de 2
    • Unscrew four screws in the top left corner by using Phillips #0 size screwdriver.
  10. Magellan Roadmate 9055-LM Touchscreen Replacement: paso 10, imagen 1 de 2 Magellan Roadmate 9055-LM Touchscreen Replacement: paso 10, imagen 2 de 2
    • Remove all the electrical tapes from different places as indicated.
  11. Magellan Roadmate 9055-LM Touchscreen Replacement: paso 11, imagen 1 de 2 Magellan Roadmate 9055-LM Touchscreen Replacement: paso 11, imagen 2 de 2
    • Remove the white clip attached with black and white wires.
    • Carefully remove the clip by pulling it to the opposite side from the clip.
  12. Magellan Roadmate 9055-LM Touchscreen Replacement: paso 12, imagen 1 de 3 Magellan Roadmate 9055-LM Touchscreen Replacement: paso 12, imagen 2 de 3 Magellan Roadmate 9055-LM Touchscreen Replacement: paso 12, imagen 3 de 3
    • Unplug the wires by pushing it down and slowly pulling it towards you.
    • After unplugging the wires, take the motherboard out.
  13. Magellan Roadmate 9055-LM Touchscreen Replacement, Touchscreen: paso 13, imagen 1 de 3 Magellan Roadmate 9055-LM Touchscreen Replacement, Touchscreen: paso 13, imagen 2 de 3 Magellan Roadmate 9055-LM Touchscreen Replacement, Touchscreen: paso 13, imagen 3 de 3
    • Unscrew four Phillips #1 screws.
    • Remove the two metal pieces on two corners.
  14. Magellan Roadmate 9055-LM Touchscreen Replacement: paso 14, imagen 1 de 2 Magellan Roadmate 9055-LM Touchscreen Replacement: paso 14, imagen 2 de 2
    • Lift touchscreen from the right side.
    • Slide the touch screen out from the top left corner.
  15. Magellan Roadmate 9055-LM Touchscreen Replacement: paso 15, imagen 1 de 1
    • Place the touchscreen gently on the table.
Conclusión
YuChe Chang
Miembro Desde 10/18/16
202 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 1-5, Catania Fall 2016 Miembro de UMass Dartmouth, Team 1-5, Catania Fall 2016
UMASSD-CATANIA-F16S1G5
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 275
