Saltar al contenido principal
Magellan Roadmate 9055-LM Speaker Replacement
Qué necesitas
  1. Magellan Roadmate 9055-LM Speaker Replacement, Magellan Roadmate 9055-LM Back Panel Disassembly: paso 1, imagen 1 de 1
    • Flip your device with back panel facing up.
  2. Magellan Roadmate 9055-LM Speaker Replacement: paso 2, imagen 1 de 3 Magellan Roadmate 9055-LM Speaker Replacement: paso 2, imagen 2 de 3 Magellan Roadmate 9055-LM Speaker Replacement: paso 2, imagen 3 de 3
    • Unscrew four Phillips #0 screws from the back panel.
  3. Magellan Roadmate 9055-LM Speaker Replacement: paso 3, imagen 1 de 2 Magellan Roadmate 9055-LM Speaker Replacement: paso 3, imagen 2 de 2
    • Unscrew two Phillips #0 screws from the back panel.
  4. Magellan Roadmate 9055-LM Speaker Replacement: paso 4, imagen 1 de 2 Magellan Roadmate 9055-LM Speaker Replacement: paso 4, imagen 2 de 2
    • Use a plastic opening tool to pop the right side of the panel.
  5. Magellan Roadmate 9055-LM Speaker Replacement: paso 5, imagen 1 de 1
    • Lifting the back panel too quickly or forcefully may damage the speaker cable and battery cable, which are still attached underneath.
    • Gently lift up the back panel.
  6. Magellan Roadmate 9055-LM Speaker Replacement: paso 6, imagen 1 de 3 Magellan Roadmate 9055-LM Speaker Replacement: paso 6, imagen 2 de 3 Magellan Roadmate 9055-LM Speaker Replacement: paso 6, imagen 3 de 3
    • Remove the tape.
    • Unplug the cable for the speaker.
  7. Magellan Roadmate 9055-LM Speaker Replacement: paso 7, imagen 1 de 3 Magellan Roadmate 9055-LM Speaker Replacement: paso 7, imagen 2 de 3 Magellan Roadmate 9055-LM Speaker Replacement: paso 7, imagen 3 de 3
    • Remove the cable of the battery.
    • Tape removal is not necessary.
  8. Magellan Roadmate 9055-LM Speaker Replacement: paso 8, imagen 1 de 1
    • Place the back panel gently on the table.
  9. Magellan Roadmate 9055-LM Speaker Replacement, Speaker: paso 9, imagen 1 de 2 Magellan Roadmate 9055-LM Speaker Replacement, Speaker: paso 9, imagen 2 de 2
    • Unscrew the left and the right screws using the ifixit screwdriver.
  10. Magellan Roadmate 9055-LM Speaker Replacement: paso 10, imagen 1 de 1
    • Now that you removed the screws, you can finally replace the speaker.
Conclusión
Una persona más ha completado esta guía.
Giovanni
Miembro Desde 10/18/16
313 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 1-5, Catania Fall 2016 Miembro de UMass Dartmouth, Team 1-5, Catania Fall 2016
UMASSD-CATANIA-F16S1G5
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 139
