Saltar al contenido principal
Magellan RoadMate 5250T-LM Screen Replacement
Qué necesitas
  1. Magellan RoadMate 5250T-LM Screen Replacement, Screen: paso 1, imagen 1 de 2 Magellan RoadMate 5250T-LM Screen Replacement, Screen: paso 1, imagen 2 de 2
    • Holding the device in place, remove all four 5 mm screws from the back of the device using a Philips Head #000 screwdriver.
    • Place screws aside. Make sure they are easily accessible for reassembling the device.
  2. Magellan RoadMate 5250T-LM Screen Replacement: paso 2, imagen 1 de 2 Magellan RoadMate 5250T-LM Screen Replacement: paso 2, imagen 2 de 2
    • Lift the back cover using a spudger.
    • Remove back cover slowly and carefully to prevent damage.
  3. Magellan RoadMate 5250T-LM Screen Replacement: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Peel back the tape securing the display connector to the motherboard.
    • To ensure proper reassembly, do not remove or fold edges of tape.
    • Use a nylon spudger to flip up the black tab on the ZIF connector.
    • Pull the ribbon cable out with tweezers.
    • The ribbon cable may fall out once the tape is removed.
  4. Magellan RoadMate 5250T-LM Screen Replacement: paso 4, imagen 1 de 2 Magellan RoadMate 5250T-LM Screen Replacement: paso 4, imagen 2 de 2
    • Undo the four clamps holding down the display.
    • Remove the display from the front cover.
Conclusión
Jaimee Mound
Miembro Desde 01/31/16
101 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 349
