Saltar al contenido principal
Magellan RoadMate 5236T-LM Display Screen Replacement
Qué necesitas
  1. Magellan RoadMate 5236T-LM Display Screen Replacement, Back Cover: paso 1, imagen 1 de 3 Magellan RoadMate 5236T-LM Display Screen Replacement, Back Cover: paso 1, imagen 2 de 3 Magellan RoadMate 5236T-LM Display Screen Replacement, Back Cover: paso 1, imagen 3 de 3
    • Place the device face down on a flat surface.
    • Remove the four 5mm screws at each corner using a #000 Phillips head screwdriver.
  2. Magellan RoadMate 5236T-LM Display Screen Replacement: paso 2, imagen 1 de 3 Magellan RoadMate 5236T-LM Display Screen Replacement: paso 2, imagen 2 de 3 Magellan RoadMate 5236T-LM Display Screen Replacement: paso 2, imagen 3 de 3
    • Gently wedge a plastic opening tool into the seam along the side of the device.
    • Slide the tool along the seam to pry apart the front and back covers.
  3. Magellan RoadMate 5236T-LM Display Screen Replacement: paso 3, imagen 1 de 2 Magellan RoadMate 5236T-LM Display Screen Replacement: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • A ribbon cable attaches the display screen and the motherboard via a ZIF connector. Remove the tape covering where the ZIF connector connects to the mother board.
    • Use tweezers to disconnect the ZIF connector from the motherboard.
    • The ZIF connector may disconnect itself from the motherboard when removing the tape.
  4. Magellan RoadMate 5236T-LM Display Screen Replacement, Display Screen: paso 4, imagen 1 de 3 Magellan RoadMate 5236T-LM Display Screen Replacement, Display Screen: paso 4, imagen 2 de 3 Magellan RoadMate 5236T-LM Display Screen Replacement, Display Screen: paso 4, imagen 3 de 3
    • Place the front panel on a flat surface, screen side down.
    • Using a plastic opening tool, apply light lifting pressure to each of the 6 casing clips to release the screen from the plastic casing.
Conclusión
2 personas más completaron esta guía.
Megan Scribner
Miembro Desde 10/18/16
315 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 4-7, Catania Fall 2016 Miembro de UMass Dartmouth, Team 4-7, Catania Fall 2016
UMASSD-CATANIA-F16S4G7
3 Miembros
5 Guías creadas
Un comentario
This would have been even a GREATER POST if, would have included the part number for the replacement screen,
But,
Just good information as to how to remove the damaged screen.
1975PINTOBOBSTER
1975PINTOBOBSTER - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 586
