Saltar al contenido principal
Magellan RoadMate 5120-LMTX Motherboard Replacement
Qué necesitas
  1. Magellan RoadMate 5120-LMTX Motherboard Replacement, Back Cover: paso 1, imagen 1 de 3 Magellan RoadMate 5120-LMTX Motherboard Replacement, Back Cover: paso 1, imagen 2 de 3 Magellan RoadMate 5120-LMTX Motherboard Replacement, Back Cover: paso 1, imagen 3 de 3
    • Power off the Magellan RoadMate before beginning.
    • Remove the six 5mm Phillips #00 screws from the back of device.
  2. Magellan RoadMate 5120-LMTX Motherboard Replacement: paso 2, imagen 1 de 3 Magellan RoadMate 5120-LMTX Motherboard Replacement: paso 2, imagen 2 de 3 Magellan RoadMate 5120-LMTX Motherboard Replacement: paso 2, imagen 3 de 3
    • Pry back cover off with a plastic opening tool just enough to see where the speaker is attached to the motherboard.
    • Do not fully open the back cover or you risk damaging the speaker wire.
    • Use a spudger to disconnect the speaker connection from the motherboard.
  3. Magellan RoadMate 5120-LMTX Motherboard Replacement, Motherboard: paso 3, imagen 1 de 3 Magellan RoadMate 5120-LMTX Motherboard Replacement, Motherboard: paso 3, imagen 2 de 3 Magellan RoadMate 5120-LMTX Motherboard Replacement, Motherboard: paso 3, imagen 3 de 3
    • There will be two 5mm Phillips #00 screws that need to be removed from the motherboard.
  4. Magellan RoadMate 5120-LMTX Motherboard Replacement: paso 4, imagen 1 de 3 Magellan RoadMate 5120-LMTX Motherboard Replacement: paso 4, imagen 2 de 3 Magellan RoadMate 5120-LMTX Motherboard Replacement: paso 4, imagen 3 de 3
    • Some devices may have a piece of tape or plastic over the ribbon cable latch. If your device has this, remove it before continuing.
    • Carefully lift the black ribbon cable latch upwards with a spudger or other similar tool.
    • Once the ribbon cable latch is opened, insert the pointed end of the spudger, or other similar tool, underneath the ribbon cable.
    • Slowly pull out the ribbon cable in a straight, flat motion with respect to the latch.
  5. Magellan RoadMate 5120-LMTX Motherboard Replacement: paso 5, imagen 1 de 2 Magellan RoadMate 5120-LMTX Motherboard Replacement: paso 5, imagen 2 de 2
    • Be careful not to touch any of the electrical components on the motherboard as damage may ensue.
    • Carefully lift the motherboard out of the plastic housing by the edges while guiding the ribbon cable through the slot.
    • Store the motherboard on a safe non-conductive surface, preferably an anti-static mat.
Conclusión
Andrew Bading
Miembro Desde 10/08/16
132 Reputación
1 Guía escrita
Equipo
IUPUI, Team 4-4, Wilson Fall 2016 Miembro de IUPUI, Team 4-4, Wilson Fall 2016
IUPUI-WILSON-F16S4G4
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 308
