Introducción
A guide to accessing the RoadMate's display.
Qué necesitas
Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
Remove the two screws on that are located on opposite sides of the board.
Carefully flip the circuit board out so you can get to the sensor easily.
Remove the tape holding the sensor to the display and take out the sensor.
Undo the 4 clasps holding the display in place.
Pop the display from the front cover.
Una persona más ha completado esta guía.
Un comentario
In order to remove the rubber plugs hiding the 4 screws, I found that a straight pin angled into the top of the plug can be used to lift them easily straight out and the plug is unharmed.
With the screws out, the back did not budge. I used the thinest blade screw driver in my jeweler's set to pry the case open and pushed on the plastic catches, one on each side that were holding it closed. They are visible in the photo of the back off.
