Saltar al contenido principal
Magellan RoadMate 1200 Back Cover Replacement
Qué necesitas
  1. Magellan RoadMate 1200 Back Cover Replacement, Back Cover: paso 1, imagen 1 de 2 Magellan RoadMate 1200 Back Cover Replacement, Back Cover: paso 1, imagen 2 de 2
    • Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
  2. Magellan RoadMate 1200 Back Cover Replacement: paso 2, imagen 1 de 1
    • Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
  3. Magellan RoadMate 1200 Back Cover Replacement: paso 3, imagen 1 de 2 Magellan RoadMate 1200 Back Cover Replacement: paso 3, imagen 2 de 2
    • Remove the back cover from the device by separating the back cover along its seam.
    • Slowly lift the cover—the speaker is screwed onto the back cover and is connected to the circuit board.
  4. Magellan RoadMate 1200 Back Cover Replacement: paso 4, imagen 1 de 2 Magellan RoadMate 1200 Back Cover Replacement: paso 4, imagen 2 de 2
    • Pull the speaker cord, horizontally, by its base, away from the motherboard.
    • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
Conclusión
2 personas más completaron esta guía.
Ross Light
Miembro Desde 04/12/10
217 Reputación
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 3,469
