Saltar al contenido principal
Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement
Qué necesitas
  1. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement, Joystick: paso 1, imagen 1 de 1
    • Unplug your controller from your console or pc.
  2. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: paso 2, imagen 1 de 3 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: paso 2, imagen 2 de 3 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: paso 2, imagen 3 de 3
    • Remove the four 3mm screws with a Philips #0 screwdriver.
  3. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: paso 3, imagen 1 de 3 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: paso 3, imagen 2 de 3 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: paso 3, imagen 3 de 3
    • Remove the six 0.9mm screws with a Phillips #00 screwdriver.
  4. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: paso 4, imagen 1 de 2 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: paso 4, imagen 2 de 2
    • Remove the metal plate cover.
    • Find the lever inside of the controller.
  5. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: paso 5, imagen 1 de 3 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: paso 5, imagen 2 de 3 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: paso 5, imagen 3 de 3
    • Insert your Flathead screwdriver into the middle of the lever to hold it in place.
    • Twist the ball to remove it from the lever.
    • Remove the ball top from the lever.
  6. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: paso 6, imagen 1 de 2 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: paso 6, imagen 2 de 2
    • Remove the four 1.1mm screws holding the lever in place with your Phillips #0 screwdriver.
  7. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: paso 7, imagen 1 de 1
    • Remove the lever from the casing of the controller.
  8. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: paso 8, imagen 1 de 2 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: paso 8, imagen 2 de 2
    • Pull the cable connected to the lever out of the socket.
    • Remove the lever from the case.
Conclusión
Una persona más ha completado esta guía.
Jordan
Miembro Desde 07/06/21
184 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 61
Ultimos 30 días: 274
Todo El Tiempo: 2,082
