Saltar al contenido principal
Mad Catz Street Fighter IV FightPad Front Case Replacement
Qué necesitas
  1. Mad Catz Street Fighter IV FightPad Front Case Replacement, Rear and Side Case: paso 1, imagen 1 de 1
    • Use tweezers to completely remove the sticker from the rear of controller.
  2. Mad Catz Street Fighter IV FightPad Front Case Replacement: paso 2, imagen 1 de 1
    • Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
  3. Mad Catz Street Fighter IV FightPad Front Case Replacement: paso 3, imagen 1 de 2 Mad Catz Street Fighter IV FightPad Front Case Replacement: paso 3, imagen 2 de 2
    • Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases.
    • Use the plastic opening tool to pry the two cases apart.
  4. Mad Catz Street Fighter IV FightPad Front Case Replacement: paso 4, imagen 1 de 2 Mad Catz Street Fighter IV FightPad Front Case Replacement: paso 4, imagen 2 de 2
    • Remove the two rubber side grips.
  5. Mad Catz Street Fighter IV FightPad Front Case Replacement, RS-DP-LS Switch: paso 5, imagen 1 de 2 Mad Catz Street Fighter IV FightPad Front Case Replacement, RS-DP-LS Switch: paso 5, imagen 2 de 2
    • Locate RS-DP-LS switch.
    • Pull upwards on the switch to remove it.
  6. Mad Catz Street Fighter IV FightPad Front Case Replacement, Circuit Board: paso 6, imagen 1 de 1
    • Locate the four 8.3 mm Phillips screws on the circuit board and remove them.
  7. Mad Catz Street Fighter IV FightPad Front Case Replacement: paso 7, imagen 1 de 3 Mad Catz Street Fighter IV FightPad Front Case Replacement: paso 7, imagen 2 de 3 Mad Catz Street Fighter IV FightPad Front Case Replacement: paso 7, imagen 3 de 3
    • Hold the controller cable at the area just before it meets the controller and slowly lift upwards to slide it out of its plastic slot and remove the circuit board.
    • Be careful with the wires connected to the circuit board itself as they are thin and delicate.
    • When reassembling the controller, make sure that the bottom plastic piece is fully inserted into its slot before replacing the circuit board.
  8. Mad Catz Street Fighter IV FightPad Front Case Replacement, Buttons: paso 8, imagen 1 de 2 Mad Catz Street Fighter IV FightPad Front Case Replacement, Buttons: paso 8, imagen 2 de 2
    • Remove the six buttons one by one by gripping the back of each one and pushing on them from the front.
    • Use tweezers to remove the rubber part of the directional pad before you try to remove the shoulder buttons.
    • When reinserting the buttons make sure they are in the correct place and oriented correctly.
  9. Mad Catz Street Fighter IV FightPad Front Case Replacement: paso 9, imagen 1 de 1
    • Remove the left and right shoulder buttons by sliding them out of their respective slots.
  10. Mad Catz Street Fighter IV FightPad Front Case Replacement, Front Case: paso 10, imagen 1 de 2 Mad Catz Street Fighter IV FightPad Front Case Replacement, Front Case: paso 10, imagen 2 de 2
    • Pull the plastic piece out from the bottom of the controller.
Conclusión
Una persona más ha completado esta guía.
Eric
Miembro Desde 09/26/12
117 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 1-7, Propen Fall 2012 Miembro de Cal Poly, Team 1-7, Propen Fall 2012
CPSU-PROPEN-F12S1G7
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 1,463
