Saltar al contenido principal
Mad Catz Street Fighter IV FightPad Circuit Board Replacement
Qué necesitas
  1. Mad Catz Street Fighter IV FightPad Circuit Board Replacement, Rear and Side Case: paso 1, imagen 1 de 1
    • Use tweezers to completely remove the sticker from the rear of controller.
  2. Mad Catz Street Fighter IV FightPad Circuit Board Replacement: paso 2, imagen 1 de 1
    • Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
  3. Mad Catz Street Fighter IV FightPad Circuit Board Replacement: paso 3, imagen 1 de 2 Mad Catz Street Fighter IV FightPad Circuit Board Replacement: paso 3, imagen 2 de 2
    • Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases.
    • Use the plastic opening tool to pry the two cases apart.
  4. Mad Catz Street Fighter IV FightPad Circuit Board Replacement: paso 4, imagen 1 de 2 Mad Catz Street Fighter IV FightPad Circuit Board Replacement: paso 4, imagen 2 de 2
    • Remove the two rubber side grips.
  5. Mad Catz Street Fighter IV FightPad Circuit Board Replacement, RS-DP-LS Switch: paso 5, imagen 1 de 2 Mad Catz Street Fighter IV FightPad Circuit Board Replacement, RS-DP-LS Switch: paso 5, imagen 2 de 2
    • Locate RS-DP-LS switch.
    • Pull upwards on the switch to remove it.
  6. Mad Catz Street Fighter IV FightPad Circuit Board Replacement, Circuit Board: paso 6, imagen 1 de 1
    • Locate the four 8.3 mm Phillips screws on the circuit board and remove them.
  7. Mad Catz Street Fighter IV FightPad Circuit Board Replacement: paso 7, imagen 1 de 3 Mad Catz Street Fighter IV FightPad Circuit Board Replacement: paso 7, imagen 2 de 3 Mad Catz Street Fighter IV FightPad Circuit Board Replacement: paso 7, imagen 3 de 3
    • Hold the controller cable at the area just before it meets the controller and slowly lift upwards to slide it out of its plastic slot and remove the circuit board.
    • Be careful with the wires connected to the circuit board itself as they are thin and delicate.
    • When reassembling the controller, make sure that the bottom plastic piece is fully inserted into its slot before replacing the circuit board.
Conclusión
Una persona más ha completado esta guía.
Jefferson Hsu
Miembro Desde 09/18/12
411 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 1-7, Propen Fall 2012 Miembro de Cal Poly, Team 1-7, Propen Fall 2012
CPSU-PROPEN-F12S1G7
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 15
Todo El Tiempo: 2,058
