Saltar al contenido principal
Mad Catz Rock Band 4 Wireless Fender Whammy Bar Replacement
Qué necesitas
  1. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement, Outer Casing: paso 1, imagen 1 de 1
    • Flip the guitar over so it is back side up. The battery compartment should be facing up.
    • Use a size J1 head screwdriver to remove the ten 5 mm short screws.
    • Use a J1 screwdriver to remove the four 5 mm long screws on the back of the device.
  2. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: paso 2, imagen 1 de 1
    • Turn the device over so the front of the guitar is facing you.
    • Using a size J1 philips head screwdriver, remove the eleven 5 mm silver screws (circled in red) around the white panel.
  3. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: paso 3, imagen 1 de 1
    • Gently lift the white panel and twist 90 degrees clockwise.
    • Using a size J1 head screwdriver, remove the two 5 mm black screws from underneath the white panel. You should now be able to pull the guitar apart.
  4. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement, Whammy Bar: paso 4, imagen 1 de 1
    • Using a size J1 philips head screwdriver, remove the four black 5 mm screws (circled in red) from the cover on the whammy bar component.
  5. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: paso 5, imagen 1 de 1
    • Using your hands, pull off the black cover and put the spring that pops out aside.
  6. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: paso 6, imagen 1 de 1
    • Using your hands, pull out the rectangular circuit board from the whammy bar component.
  7. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: paso 7, imagen 1 de 1
    • Follow the cord for the circuit board from the whammy bar, and using your hands pull it out of the main circuit board.
  8. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: paso 8, imagen 1 de 1
    • Pull out the whammy bar.
Conclusión
Equipo
USF Tampa, Team 1-1, Cagle Fall 2016 Miembro de USF Tampa, Team 1-1, Cagle Fall 2016
USFT-CAGLE-F16S1G1
Miembros de 4
6 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 16
Todo El Tiempo: 1,773
