Saltar al contenido principal
Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement
Qué necesitas
  1. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement, Outer Casing: paso 1, imagen 1 de 1
    • Flip the guitar over so it is back side up. The battery compartment should be facing up.
    • Use a size J1 head screwdriver to remove the ten 5 mm short screws.
    • Use a J1 screwdriver to remove the four 5 mm long screws on the back of the device.
  2. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement: paso 2, imagen 1 de 1
    • Turn the device over so the front of the guitar is facing you.
    • Using a size J1 philips head screwdriver, remove the eleven 5 mm silver screws (circled in red) around the white panel.
  3. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement: paso 3, imagen 1 de 1
    • Gently lift the white panel and twist 90 degrees clockwise.
    • Using a size J1 head screwdriver, remove the two 5 mm black screws from underneath the white panel. You should now be able to pull the guitar apart.
  4. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement, Sync Component: paso 4, imagen 1 de 1
    • Remove the two black 5 mm screws (circled in red) from the back of the power button component using a size J1 philips head screwdriver. You can identify this by the code J5-B on the component.
    • Lift the small, rectangular circuit board out and set it aside.
  5. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement: paso 5, imagen 1 de 1
    • Locate the sync component hardware. It is a small circuit board that sits sideways with respect to the other circuit boards around it.
    • Remove the two 5mm black screws (circled in red) holding the circuit board in place using a size J1 philips head screwdriver. The component should now slide out vertically.
  6. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement: paso 6, imagen 1 de 1
    • Follow the wires connected to the sync component back to the main circuit board. Unplug the component from the main circuit board.
Conclusión
2 personas más completaron esta guía.
Hollynn Ricker
Miembro Desde 09/28/16
451 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 1-1, Cagle Fall 2016 Miembro de USF Tampa, Team 1-1, Cagle Fall 2016
USFT-CAGLE-F16S1G1
4 Miembros
6 Guías creadas
Un comentario
How do I replace the sync wire? Where can I purchase a new sync component?
Ange - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 28
Todo El Tiempo: 2,431
