Saltar al contenido principal
Macintosh Powerbook 5300cs Trackpad Replacement
Qué necesitas
  1. Macintosh Powerbook 5300cs Trackpad Replacement, Battery: paso 1, imagen 1 de 1
    • The battery compartment is located in the front-right side of the laptop.
  2. Macintosh Powerbook 5300cs Trackpad Replacement: paso 2, imagen 1 de 1
    • To insert the battery, gently slide it into the compartment until it clicks in place.
    • To remove, slide the button highlighted in the red rectangle to the right to release the battery and slide it from the compartment.
  3. Macintosh Powerbook 5300cs Trackpad Replacement, Keyboard: paso 3, imagen 1 de 1
    • With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
  4. Macintosh Powerbook 5300cs Trackpad Replacement: paso 4, imagen 1 de 2 Macintosh Powerbook 5300cs Trackpad Replacement: paso 4, imagen 2 de 2
    • Carefully pull up on the front of the keyboard to pop it out from the case.
    • Then slide the back out so the keyboard becomes nearly free.
  5. Macintosh Powerbook 5300cs Trackpad Replacement: paso 5, imagen 1 de 3 Macintosh Powerbook 5300cs Trackpad Replacement: paso 5, imagen 2 de 3 Macintosh Powerbook 5300cs Trackpad Replacement: paso 5, imagen 3 de 3
    • Disconnect the ribbon that is connecting the keyboard to the rest of the computer.
    • Pull the keyboard out and repair or replace as needed.
  6. Macintosh Powerbook 5300cs Trackpad Replacement, Trackpad: paso 6, imagen 1 de 3 Macintosh Powerbook 5300cs Trackpad Replacement, Trackpad: paso 6, imagen 2 de 3 Macintosh Powerbook 5300cs Trackpad Replacement, Trackpad: paso 6, imagen 3 de 3
    • Remove the front plastic panel of the laptop by carefully lifting it up.
  7. Macintosh Powerbook 5300cs Trackpad Replacement: paso 7, imagen 1 de 1
    • Remove the orange stripped ribbon that connects the trackpad to the rest of the laptop by carefully pulling up.
  8. Macintosh Powerbook 5300cs Trackpad Replacement: paso 8, imagen 1 de 2 Macintosh Powerbook 5300cs Trackpad Replacement: paso 8, imagen 2 de 2
    • With a Torx #9 screwdriver, remove the two .20 in. screws circled in red that are holding the trackpad in place.
    • Then disconnect the ribbon highlighted with the red rectangle connecting the trackpad to the laptop.
  9. Macintosh Powerbook 5300cs Trackpad Replacement: paso 9, imagen 1 de 1
    • The trackpad can now be removed from the laptop.
Conclusión
Una persona más ha completado esta guía.
Ronan
Miembro Desde 10/10/11
63 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 6-1, Regan Fall 2011 Miembro de Cal Poly, Team 6-1, Regan Fall 2011
CPSU-REGAN-F11S6G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 1,031
