Saltar al contenido principal
Macintosh PowerBook 165c Hard Drive Replacement
Qué necesitas
  1. Macintosh PowerBook 165c Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Orient the computer so the battery is facing you.
    • Slide the gray plastic battery cover to the right.
  2. Macintosh PowerBook 165c Hard Drive Replacement: paso 2, imagen 1 de 1
    • Pull the battery toward yourself until it is fully detached.
  3. Macintosh PowerBook 165c Hard Drive Replacement, Input/Output Door: paso 3, imagen 1 de 1
    • Orient the computer right side up with the rear facing you.
    • Open the Input/Output (I/O) door.
  4. Macintosh PowerBook 165c Hard Drive Replacement: paso 4, imagen 1 de 1
    • Carefully bend the door into an arch until one of the pins releases from its slot.
    • Once one of the pins is free, remove the I/O door from the computer.
  5. Macintosh PowerBook 165c Hard Drive Replacement, Lower Case: paso 5, imagen 1 de 1
    • Orient the computer with the bottom facing up and rear facing you. You should be able to read the Macintosh label in this position.
  6. Macintosh PowerBook 165c Hard Drive Replacement: paso 6, imagen 1 de 1
    • Use a T8 torx screwdriver to remove the 6.8mm long screw above and to the right of the modem jack.
    • Twist counter clockwise to remove the screw.
  7. Macintosh PowerBook 165c Hard Drive Replacement: paso 7, imagen 1 de 1
    • Use a T10 torx screwdriver to remove the four, 18mm long screws from the lower case.
  8. Macintosh PowerBook 165c Hard Drive Replacement: paso 8, imagen 1 de 2 Macintosh PowerBook 165c Hard Drive Replacement: paso 8, imagen 2 de 2
    • Place your hands on the lower case, just above the I/O panel, and slowly lift the lower case a few inches above the main body of the computer.
    • Release the large, gray interconnect ribbon cable just behind the I/O panel.
    • Caution: Lower case cannot be fully removed until two plastic clips in the front corners are released. See the following step for details.
  9. Macintosh PowerBook 165c Hard Drive Replacement: paso 9, imagen 1 de 2 Macintosh PowerBook 165c Hard Drive Replacement: paso 9, imagen 2 de 2
    • Place your thumb on the upper case, inside the empty battery slot, and your index finger near your thumb on the left side of the lower case.
    • Pinch your thumb and index finger towards each other to release the clip. Without releasing pressure on the pinch grip, use your index finger to push the lower case upwards.
    • Lift the lower case to remove it.
  10. Macintosh PowerBook 165c Hard Drive Replacement, Modem Card: paso 10, imagen 1 de 1
    • Orient the computer so the ports are facing you.
  11. Macintosh PowerBook 165c Hard Drive Replacement: paso 11, imagen 1 de 2 Macintosh PowerBook 165c Hard Drive Replacement: paso 11, imagen 2 de 2
    • Locate the Modem Card on the lower case.
    • Use a T8 torx screwdriver to remove the two, 7.7mm long screws from the two corners.
    • The modem card is an optional component on the Macintosh 165c, and may not be included in all devices.
  12. Macintosh PowerBook 165c Hard Drive Replacement: paso 12, imagen 1 de 1
    • Lift the modem card directly upward until it releases from the connector.
    • If the modem card is difficult to remove, gently jostle it back and forth as you lift up.
  13. Macintosh PowerBook 165c Hard Drive Replacement, RAM and PSRAM Expansion Card: paso 13, imagen 1 de 2 Macintosh PowerBook 165c Hard Drive Replacement, RAM and PSRAM Expansion Card: paso 13, imagen 2 de 2
    • Locate and lift ram card directly up until connector releases.
    • Move the card back and forth gently if the connector does not release immediately.
  14. Macintosh PowerBook 165c Hard Drive Replacement: paso 14, imagen 1 de 2 Macintosh PowerBook 165c Hard Drive Replacement: paso 14, imagen 2 de 2
    • Locate and lift the PSRAM expansion card vertically until connector releases.
    • If the PSRAM expansion card is difficult to remove, gently jostle it back and forth as you lift up.
    • The PSRAM expansion card is an optional component, and may not be included in all devices.
  15. Macintosh PowerBook 165c Hard Drive Replacement, Daughterboard: paso 15, imagen 1 de 1
    • Use T8 torx screwdriver to remove four, 7.7mm long screws from the perimeter of the daughterboard.
  16. Macintosh PowerBook 165c Hard Drive Replacement: paso 16, imagen 1 de 1
    • Life the daughterboard directly up to remove it from the connector.
    • If the daughterboard does not easily release from the connector, gently jostle it back and forth as you lift up.
  17. Macintosh PowerBook 165c Hard Drive Replacement, Hard Drive: paso 17, imagen 1 de 1
    • Use a T8 torx screwdriver to remove the five, 6.8mm long screws on the drive retainer.
  18. Macintosh PowerBook 165c Hard Drive Replacement: paso 18, imagen 1 de 3 Macintosh PowerBook 165c Hard Drive Replacement: paso 18, imagen 2 de 3 Macintosh PowerBook 165c Hard Drive Replacement: paso 18, imagen 3 de 3
    • Orient the computer so the plastic clip in top left corner of the lower case is facing you. Release the clip by lifting the retainer. You may need to adjust the position of the hard drive to remove the retainer.
    • Lift the drive retainer out.
  19. Macintosh PowerBook 165c Hard Drive Replacement: paso 19, imagen 1 de 1
    • Pull the orange connector attached to the ribbon cable until the connector releases from the motherboard.
  20. Macintosh PowerBook 165c Hard Drive Replacement: paso 20, imagen 1 de 1
    • Lift the hard drive to remove it.
Conclusión
2 personas más completaron esta guía.
John
Miembro Desde 10/12/11
88 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 6-3, Regan Fall 2011 Miembro de Cal Poly, Team 6-3, Regan Fall 2011
CPSU-REGAN-F11S6G3
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 23
Todo El Tiempo: 3,451
