Saltar al contenido principal
Macintosh PowerBook 1400 Series Keyboard Replacement
Qué necesitas
  1. Macintosh PowerBook 1400 Series Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the device upside down and then locate the battery latch near the front of the device.
  2. Macintosh PowerBook 1400 Series Keyboard Replacement: paso 2, imagen 1 de 1
    • Slide the latch to the left to release the battery.
  3. Macintosh PowerBook 1400 Series Keyboard Replacement: paso 3, imagen 1 de 1
    • Continue holding the latch then gently pull the battery out of the device.
    • Place the battery in a safe location.
  4. Macintosh PowerBook 1400 Series Keyboard Replacement, CD-ROM Drive: paso 4, imagen 1 de 1
    • Locate the CD-ROM Drive latch.
  5. Macintosh PowerBook 1400 Series Keyboard Replacement: paso 5, imagen 1 de 1
    • Slide the latch to the right to release the CD ROM drive.
  6. Macintosh PowerBook 1400 Series Keyboard Replacement: paso 6, imagen 1 de 1
    • Continue holding the latch then gently pull the CD-ROM Drive out of the device.
    • Place the CD ROM drive in a safe location.
  7. Macintosh PowerBook 1400 Series Keyboard Replacement, Keyboard: paso 7, imagen 1 de 1
    • Locate the speaker cover.
  8. Macintosh PowerBook 1400 Series Keyboard Replacement: paso 8, imagen 1 de 1
    • Press firmly on each end of the speaker cover and slide it to the left.
  9. Macintosh PowerBook 1400 Series Keyboard Replacement: paso 9, imagen 1 de 1
    • Gently lift the speaker cover to remove it.
  10. Macintosh PowerBook 1400 Series Keyboard Replacement: paso 10, imagen 1 de 1
    • Lift the keyboard up from the back using a spudger(wedge side).
  11. Macintosh PowerBook 1400 Series Keyboard Replacement: paso 11, imagen 1 de 1
    • Gently lift the keyboard until only the ribbon cable remains attached.
  12. Macintosh PowerBook 1400 Series Keyboard Replacement: paso 12, imagen 1 de 1
    • Tilt the keyboard away from the screen.
  13. Macintosh PowerBook 1400 Series Keyboard Replacement: paso 13, imagen 1 de 1
    • Locate the six screws that secure the heatsink.
  14. Macintosh PowerBook 1400 Series Keyboard Replacement: paso 14, imagen 1 de 1
    • Remove the six screws from the heatsink using the Philips #1 screwdriver.
  15. Macintosh PowerBook 1400 Series Keyboard Replacement: paso 15, imagen 1 de 1
    • Lift the heatsink from the side closest to the laptop screen.
  16. Macintosh PowerBook 1400 Series Keyboard Replacement: paso 16, imagen 1 de 1
    • Remove the heatsink.
  17. Macintosh PowerBook 1400 Series Keyboard Replacement: paso 17, imagen 1 de 1
    • Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
  18. Macintosh PowerBook 1400 Series Keyboard Replacement: paso 18, imagen 1 de 1
    • Detach the ribbon cable.
  19. Macintosh PowerBook 1400 Series Keyboard Replacement: paso 19, imagen 1 de 1
    • Remove the keyboard.
Conclusión
Una persona más ha completado esta guía.
Sean Bent
Miembro Desde 04/01/11
41 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 10-39, Forte Spring 2011 Miembro de Cal Poly, Team 10-39, Forte Spring 2011
CPSU-FORTE-S11S10G39
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 2,454
