Saltar al contenido principal
Macintosh PowerBook 1400 Series CD-ROM Drive Replacement
  1. Macintosh PowerBook 1400 Series CD-ROM Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the device upside down and then locate the battery latch near the front of the device.
  2. Macintosh PowerBook 1400 Series CD-ROM Drive Replacement: paso 2, imagen 1 de 1
    • Slide the latch to the left to release the battery.
  3. Macintosh PowerBook 1400 Series CD-ROM Drive Replacement: paso 3, imagen 1 de 1
    • Continue holding the latch then gently pull the battery out of the device.
    • Place the battery in a safe location.
  4. Macintosh PowerBook 1400 Series CD-ROM Drive Replacement, CD-ROM Drive: paso 4, imagen 1 de 1
    • Locate the CD-ROM Drive latch.
  5. Macintosh PowerBook 1400 Series CD-ROM Drive Replacement: paso 5, imagen 1 de 1
    • Slide the latch to the right to release the CD ROM drive.
  6. Macintosh PowerBook 1400 Series CD-ROM Drive Replacement: paso 6, imagen 1 de 1
    • Continue holding the latch then gently pull the CD-ROM Drive out of the device.
    • Place the CD ROM drive in a safe location.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 10-39, Forte Spring 2011 Miembro de Cal Poly, Team 10-39, Forte Spring 2011
CPSU-FORTE-S11S10G39
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 2,777
