Introducción
This guide will show you how to replace the SuperDrive from your laptop (requires a SATA SuperDrive).
Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Remove the following screws from the optical drive side of the rear vent:
Two 10 mm T8 Torx
Two 5.2 mm Phillips
Remove the single 12 mm Phillips screw securing the top of the rear speaker housing to the upper case.
Pull the optical drive cable connector away from the body of the optical drive.
Remove the two black Phillips #0 screws securing the small metal mounting bracket. Transfer this bracket to your new optical drive or hard drive enclosure.
67 personas más completaron esta guía.
9 comentarios
Step 4-5 There is a screw in the center of the bar that looks like it might not be a hold down. It is. Be sure to remove it along with the other screws at each end of the bar per step 4 & 5 instructions.
Step 4-5
There is a screw in the center of the bar that must be removed, in addition to the screws noted in the instructions for step 4 and step 5. It looks like the bar might go over the screw. It doesn't. The center screw holds the bar down. Remove it.
