Saltar al contenido principal
MacBook Unibody Model A1342 Lower Case Replacement
Qué necesitas
  1. MacBook Unibody Model A1342 Lower Case Replacement, Lower Case: paso 1, imagen 1 de 1
    • Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
  2. MacBook Unibody Model A1342 Lower Case Replacement: paso 2, imagen 1 de 3 MacBook Unibody Model A1342 Lower Case Replacement: paso 2, imagen 2 de 3 MacBook Unibody Model A1342 Lower Case Replacement: paso 2, imagen 3 de 3
    • The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
    • Slightly lift the lower case near the vent opening.
    • Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
    • The location of these three clips is shown in the third picture.
Conclusión
74 personas más completaron esta guía.
2 comentarios
Apple has a recall on this part, so you can get a replacement for an improved version free and save yourself $149.99. Check out http://www.apple.com/support/macbook-bot...
Shane - Contestar
Would the Macbook Pro back cover also fit this?
wow - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 37
Todo El Tiempo: 69,700
